abs inop light?
Old May 1, 2006 | 02:32 PM
95okz28's Avatar
abs inop light?
what would cause the abs light to come on? mine has been on since i bought it and i have checked all the connections and grounds that i know of. any suggestions to get this light off would be great.
There has been a engine swap the car is a 95 engine is 96/97. No mods other than tb bybass and flowmaster exhaust.
Old May 1, 2006 | 02:35 PM
OBE1 95Z28's Avatar
Re: abs inop light?
There's probably around 40 different codes that can cause the ABS light to come on; the system can be scanned to see what the code is for. Common failures are dirty sensors and burn't wires close to the exhaust manifold.
Old May 1, 2006 | 04:01 PM
Dansean1's Avatar
Re: abs inop light?
You will be surprised by what can set it off. I had one too and it turned out to be a bulb in the back of the car.
Check for the stupid stuff to. I had a buddy with a scanner do it for me, scanned the car while he was driving.
Have someone who is electrically knowledgeable and check the volts by each hub. Basically, check for the obvious/stupid stuff before going to a shop.
grabbem88
20
Dec 27, 2015 07:42 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
