abs inop light
Re: abs inop light
Check for loose grounds on the ground post on the passenger fender right by the positive post. It's the one right behind the battery. Theres ground wires, then a nut, then more wires, then another nut. My bottom nut came loose and kicked on my light. Basically a poor ground.
Ken R.
Ken R.
It was the ground wire on My pass side wheel well by the battery was just a little loose.
I want to thank you for this thread. My ABS Inop light is out, and it is running much better. I was also showing a P0138 High voltage O2 bank 1 Sensor 2, but that could still come back on me.
Thank you again.
Thank you again.
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
