ABS deleted -weak front brakes with line-loc
When you do stupid things you have to ask stupid questions to fix your stupid mistake.
Here's mine.
I deleted my ABS a few years back by removing the unit and hooking the brake lines from the master cylinder to the original front and rear brake lines. Everything worked fine to that point.
I then installed a line lock between the master cylinder and the tee where the front brakes lines run to each wheel. In the beginning, if I used the line-loc it would hold in the water box, but not on the street (I could push through with ET Streets).
Now it doesn't even want to hold and the brakes seem soft at idle. I have to pump them up to get firm and I'm pushing through the water box even if I pump up the brakes.
I've bled the lines several times, no difference.
I installed a new cam this winter that idles at 67-74 MAP (8-9 in vacuum). My Hot cam idled around 50 MAP and I was having slight problems back then.
Is it time for a vacuum canister? Or do I need to look at the master cylinder?
Or, did I do something really stupid when I deleted the ABS?
Here's mine.
Looking at the service manual, I may have connected the brake lines to the wrong port on the master cylinder. There are two pictures and the lines are reversed depending on whether you have traction control or not.
I do not believe I have traction control on a 94 Camaro.
Does the rear port of the master cylinder go to front or rear brakes on the 94?
Magenta_Hearts
Mar 29, 2017 08:54 PM
jj_burchiel
Mar 21, 2015 12:51 AM
Brake_L8
Jan 20, 2015 09:44 AM
Hurin
Dec 13, 2014 07:38 PM
Jul 4, 2005 05:00 PM
