ABS/Brake Lights ON dash. First Step To Diagnose?
Old Aug 17, 2009 | 05:14 PM
ENRKyle20's Avatar
is there anything computer related with the ALDL and freescan or datamaster that is ABS related. ever since i installed my motor both lights are on 90% of the time. sometimes they are both off. Is there some codes or anything?. I have everything plugged in and I checked all the fuses.
Old Aug 17, 2009 | 06:07 PM
rclearyiii's Avatar
ABS Light
I once had a problem with the ABS light staying on. It turned out that when I had installed spark plug wires that one of them was too close to the abs sensor wiring on the drivers side. I modified the plug wire position and the problem went away.
Old Aug 17, 2009 | 07:44 PM
As far as I know, you can't scan the EBCM with Freescan or DataMaster. You need a scanner specifically for the braking system.
Have you verified there are no problems with the brake hydraulic systems? The "BRAKE" light comes on when the differential pressure switch on the side of the ABS motor unit senses a pressure imbalance between the front and rear braking systems. Leaks, air in the lines, problems with the master cylinder, etc.
Old Sep 28, 2009 | 06:35 PM
crazypurgatory's Avatar
Lightbulb
I found this If I had a cable I would try it out for 39 bucks to see if to would work on my 97 Z28.
http://www.obdscan.net/obdscan_gm_vpw_enhance.htm
Old Sep 29, 2009 | 07:15 AM
They say it works on :
Chevrolet Camero - 2002-2003
doh!
Still going to buy it?
Old Sep 29, 2009 | 07:33 AM
doh!
Yea they also said it might work on others too.
Worth a shot being that I have not seen and thing for my 97 Z28 Or his 95.
Old Apr 3, 2010 | 11:54 AM
ENRKyle20's Avatar
Does freescan or data master (or OBDI for that mateR) interact with ABS at all ?
DirtyDaveW
Dec 1, 2016 05:37 PM
Heathen1
Jan 2, 2016 04:27 PM
Alien
Jun 27, 2015 01:13 PM
fpete1992
Dec 11, 2014 03:51 PM
