99 ss wheels
Old Nov 3, 2006 | 10:14 PM
pimarine21's Avatar
Question 99 ss wheels
i have a 1999 camaro ss and have the 17 inchers and was wondering if there is a back spacing on the car. i recently got 2 new tires and had the front replaced because they were worn out worse and they put the new on the front and then i put the front on the rear. it seems to be pulling both ways when i hit bumbs and such. I want to know if there is a difference in rims before i do an alignment.
Old Nov 4, 2006 | 02:21 PM
MOhara6012's Avatar
hey,
I just installed the SS wheels on my 94 Z28.
The OEM GM SS wheels are the same width front and rear.
17 x 9.0
The pulling is an alignment issue.
Mike
Old Nov 4, 2006 | 06:04 PM
RE AND CHERYL's Avatar
Both front and rear rims are identical. Even when the alignment is perfect those 275 wide tires will pull over bumps and follow every line in the road. A bad alignmet will make this much worse. When you get the car aligned make sure you tell the tech you want it right, not just close.
Old Nov 4, 2006 | 11:45 PM
pimarine21's Avatar
well i just started going to uti (universal technical institute) and im just starting underbody class and will be learning how to do alignments next week, guess the ss is gonna be the ginni pig
Old Nov 5, 2006 | 02:09 AM
wdtiger's Avatar
like Re said... 275s will pull really bad in ruts/groove/bumps inthe road. It's called tramlining. I have a set of 275s on mine... The roads in AK are REALLY bad an pull my car all over the place.
Still, it's possible the alignment is off.
force10
Aug 10, 2015 08:30 AM
30th Anniv Z28
Aug 1, 2015 10:39 AM
240ssLs3
Jul 13, 2015 05:06 PM
Slayer
Jul 4, 2015 03:06 PM
jasonduaine
Jun 4, 2015 09:29 AM
