94 Suspension
Old Oct 12, 2006 | 09:34 AM
camaroz28adam's Avatar
94 Suspension
I have a 94 Camaro V6. The thing rides really really rough. When you go down the road, every crack I hit it makes a thug noise. What can i do to fix this problem? Im getting new tires on it hoping that will help. Someone else suggested stiffer shock or lowering springs. Can anyone give me any recommendations?
Old Oct 12, 2006 | 11:12 AM
Sam Strano's Avatar
Re: 94 Suspension
Stiffer shocks and lowering springs? No.
You need *better* shocks. Parts of their valving are stiffer, parts are softer. The stock shocks just have really bad valving, and they are responsible for most of your stiff legged ride.
Bilstein HD's @ $349 are a good option for a V-6, but we do run a different HD rear shock that what's in the catalog. Recently Bilstein screwed up the rear HD's for this car, so we started using another HD for another F-body.
Old Oct 12, 2006 | 07:55 PM
CALL911's Avatar
Re: 94 Suspension
Sam is correct. Lowering your car and going with a stiffer shock will generally make your ride even more of a rough ride.
Sounds like you need a new set of shocks to me. Tire's shouldn't make any difference unless you are changing sizes, or have been running around on flat ones.
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
97blackformula
Aug 27, 2015 06:02 PM
force10
Jul 30, 2015 04:56 PM
mrwz28
Jul 8, 2015 09:11 PM
