8 point roll bar install?
Old Feb 28, 2009 | 12:16 AM
1slo93z's Avatar
I have a 93 z28 and picked up a 8 point roll bar.Does anyone know the correct mounting points and height location of side bars and the back cross bar?
Old Feb 28, 2009 | 04:15 PM
n2ceptor's Avatar
Check with Wolfe....
http://www.wolferacecraft.com/instal...y25-2cage.aspx
Old Mar 1, 2009 | 11:16 AM
NHRA requirements:
-Hoop can not be more than 6" behind the driver's helmet.
-Hoop must be at least 3" above driver's helmet (hard to do with a 4th Gen, and often not enforced)
-Rear braces can not be attached more than 5" below top of hoop.
-Side bar must pass the drivers arm midway between the shoulder and the elbow.
-Crossbar and rear braces must be welded to hoop.
-Swingout sidebars allowed, with correct hardware.
-Crossbar height must be no more than 4" below driver's shoulders, and not above shoulders.
-Cars without frame (e.g. 4th Gens) use 6" square, 1/8" thick plates on both the top and bottom of the floor, bolted through the floor with at leat four 3/8" bolts.
-Alternatively, the hoop can be supported on a plate that is welded to the rocker sill.
-Welding must be free of slag.
-No grinding of welds is permitted.
-Roll bar must be padded anywhere driver's helmet can make contact with it.
-Padding must have a minimum of 1/4" compression, or meet SFI 45.1.
http://www.injuneer.com/images/photo.../DCP03794a.jpg
Old Mar 1, 2009 | 11:40 AM
1slo93z's Avatar
Thanks Fred for the info you are a definite asset to this web sight!!!!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
WildRidez
Feb 23, 2015 07:24 PM
