300lb or 275lb QA1 springs for street/strip car?
Old Jun 6, 2008 | 09:56 PM
trans9_5am's Avatar
Which spring rate should i got with and why? I have QA1 single adjustables all the way around with 170lb springs in the back (or atleast i think thats what they are).
Brandon
Old Jun 7, 2008 | 06:30 AM
Capn Pete's Avatar
For the front?? I would think you'd want the heavier spring rate. For weight transfer, you want the front to lift, and not squat too much on the way back down, right? (hence the typical "90/10" front shocks). I think a heavier front spring would compliment the 90/10 shock theory .
But that's just my un-educated/scientifical guess .
Old Jun 7, 2008 | 10:30 AM
trans9_5am's Avatar
Well they say the lighter ones (275lb) are for drag race, the 300lb are for street/strip and the heavier ones (315lb) are for road race?
Brandon
Oh and yes for the front. I have 170lb QA1 springs in the back!
Old Jun 7, 2008 | 11:37 AM
Capn Pete's Avatar
Which brand are these springs? And do any/all of them raise/lower the ride height from stock?
315 lb springs aren't quite enough for "road race" IMO . But I don't see the advantage to soft front springs for drag racing?? AND, the rear rate actually seems too high?! Heck, I've got Sam Strano's REAL "road racing" suspension, which gives 550 lb springs in the front, but only 150 in the back?! I wouldn't think you'd want a stiffer spring in the back for drag racing?!?!?!
I think we need more experience/opinions!!
Old Jun 13, 2008 | 12:15 PM
UMI Performance's Avatar
Former Vendor
The QA1 springs are more drag race oriented. We recommend the following below when choosing QA1 springs-
275lb- For cars with front end weight reduction such as AC removal, front bumper support removed ect. Drag Race only
300lb- For drag racing and vehicles that see normal street use or driving.
Hope that helps!
Ryan
Old Jun 14, 2008 | 02:20 PM
trans9_5am's Avatar
Thanks,
Guess i will just go with the 300lb springs since i dont have any front end weight reduction at this moment.
Brandon
Old Jun 22, 2008 | 05:17 PM
wdtiger's Avatar
I'll admit that i don't understand drag racing that well (i do the twisty stuff), but why bother replacing the fronts with 300lb springs? The stock fronts are 292lb. Seems like a waste of time and money for an extra 8lbs of spring. Is there something more to these springs i'm not getting?
Old Jun 22, 2008 | 08:29 PM
trans9_5am's Avatar
Very good question. Does anyone know the answer to this?
Old Jun 22, 2008 | 10:56 PM
96SilverRam's Avatar
I'm running the HAL QA1 12 way coilovers at all four corners and I used the 300 lb linear rate QA1 spring up front, rears are the 150 lb linear rate QA1 (I think, maybe 175 lb ?). The car has BMR / Strano / etc. everywhere with a street / track alignment. To be honest, QA1's are probably not the best springs you can run for daily driving, but they perform much better than I would have expected on the street. My car feels very good when aggressively driving the package on twisty roads, plus a good compromise for the strip. I'm sure having a complete suspension setup will make a huge difference, still impressed with the street performance of the (dis-advantaged) QA1.
Old Jun 23, 2008 | 08:45 PM
stopthatman's Avatar
nice setup - aren't the stock LT1 springs 292 front 110 back? my car never rode so well as when it was stock.
Old Jun 23, 2008 | 09:17 PM
I think your front numbers are correct, but I thought the rears were a little higher rate spring ? I would agree a totally stock WS6 suspension rides pretty good on the street; although, this setup is pretty close on a street ride and it handles damn well when it's pushed.
Old Jun 23, 2008 | 11:41 PM
Sinister95Z's Avatar
I decided to run a set of stock springs up front on the QA1 double adjustable's. Maybe you could try that out for awhile and then switch to the QA1 springs if you are not happy?
Noenav
Mar 1, 2019 07:38 AM
ModdedNerd
Dec 25, 2014 05:51 PM
MadMav
Dec 14, 2014 06:19 AM
cmdeshon
Dec 12, 2014 10:51 PM
USAirman93
Nov 24, 2014 03:37 PM
