2 piece brakes
Old Sep 16, 2005 | 10:12 PM
Stang Spanker's Avatar
Question 2 piece brakes
Can someone tell me what the benefit of 2 piece brakes are versus standard 1 piece? Thanks!
Old Sep 16, 2005 | 10:26 PM
Re: 2 piece brakes
Never heard any called that before.
Do you mean dual piston disc brakes? They usually have more clamping power.
Old Sep 16, 2005 | 10:34 PM
Re: 2 piece brakes
Sorry, I should have been more specific. I meant the 2 piece rotors, like these:
http://thunderracing.com/catalog/sum.../s52_large.jpg
Old Sep 16, 2005 | 11:19 PM
Re: 2 piece brakes
The "hat" can be made out of lighter weight materials than the rotor.
Old Sep 16, 2005 | 11:22 PM
Re: 2 piece brakes
Oh, cool. So I assume the theory is that with less weight on the rotor, you have less rotating mass and therefore stop faster?
Old Sep 17, 2005 | 10:52 AM
Greed4Speed's Avatar
Re: 2 piece brakes
Somewhat, but that is also less heat they can take before transferring it to other parts of the brake system.
Old Sep 18, 2005 | 08:15 AM
joe-96z1le's Avatar
Re: 2 piece brakes
Two piece rotors reduce "unsprung weight" on the suspension. I believe reducing unsprung weight improves suspension response which would be a benefit for those auto-crossing, etc. But, for a street car, the biggest benefit is probably just that they look pretty cool.
Old Sep 18, 2005 | 10:09 AM
Re: 2 piece brakes
And if they're on a track they're running higher temp rated pads that can take the higher heat.
alex5366
Jun 14, 2015 10:31 PM
May 1, 2015 01:14 PM
Dec 4, 2014 11:56 AM
bossco
Nov 29, 2014 10:18 AM
