1995 Z28 abs codes
Old 06-24-2014, 12:18 PM
Patricklt1's Avatar
1995 Z28 abs codes
I was finally able to have the car read and these three popped up
Code 22- rf wheel speed o mph
Code 53- rf channel release to long
Code 78- rf solenoid ? Or short to battery
I have been reading about the wheel speed sensors not really being bad but just need cleaning and connections checked. The car brakes fine until just before you stop then it feels like the brake lets up then reapplies at about 1 mph harder than expected. Just enough for everyone's head to bob forward. While all this is happening the traction loss light pops on and after you are stopped for a few seconds it goes off and all is well..
Any thoughts or input is appreciated
Patrick
Patricklt1 is offline
Old 06-24-2014, 01:18 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Re: 1995 Z28 abs codes
The front wheel speed sensor is not repairable or cleanable since it is sealed inside the front wheel hub assembly. But the most common problem is the cable from the hub to the body.
The behavior of the low traction light is consistent with the ABS operation during an emergency stop.
GaryDoug is offline
Old 06-27-2014, 02:07 PM
Patricklt1's Avatar
Smile Re: 1995 Z28 abs codes
Well the ABS problems are solved. The pigtail from the right wheel sensor was bad it's fixed and now the brakes work like a dream.
Big thanks for the advise I appreciate it.
Patrick
Garcia5
07-07-2022 06:51 PM
calaban
05-18-2020 06:43 PM
10-31-2016 11:09 AM
01-05-2015 07:14 PM
pete53
12-09-2014 07:31 AM
Quick Reply: 1995 Z28 abs codes
