Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
Final chance at getting a set of Bob Bishop C5 to F-body Brake Conversion Brackets...
Old Jun 22, 2004 | 01:20 PM
  #481
Z28barnett's Avatar
Re: Re: Re: Spare Tire Question - Will stock spare clear 13" brakes?
[QUOTE]Originally posted by Z28barnett
[B]Good info,
I hadn't thought about a corvette spare.
The height difference would be 3.64" using your calcuations and depending on how exact the tire dimensions are.
I just checked the spare tire well. There isn't enough room for my finger much less my hand.
I don't think anything larger in dia will fit.
Perhaps the C4 spare with a motorcycle tire might fit. I don' t see any easy way to handle this.
Love it or leave it, not a problem on a race car, 50% reduction in usefulness of the spare on a street car.
Old Jun 22, 2004 | 02:47 PM
  #482
PediDr2's Avatar
Re: Re: Re: Re: Spare Tire Question - Will stock spare clear 13" brakes?
[B]
Good info,
My option was to toss the spare in the basement and get AAA. Since I have 3 cars a wife and 3 kids it was an easy choice.
Another idea if you have the bucks is to mount runflats
Old Jun 22, 2004 | 02:51 PM
  #483
Rottluver's Avatar
Re: Re: Re: Re: Re: Spare Tire Question - Will stock spare clear 13" brakes?
Don't you need the electronics IN the car to use runflats? Or are there ways to do without that?
Old Jun 22, 2004 | 03:35 PM
  #484
PediDr2's Avatar
Re: Re: Re: Re: Re: Re: Spare Tire Question - Will stock spare clear 13" brakes?
Yes, you need the sensors on the wheels and the dash display.
http://www.tirerack.com/accessories/...artire_all.jsp
I'm sure there are other systems out there. Not a cheap way to go.
Old Jun 22, 2004 | 03:37 PM
  #485
Rottluver's Avatar
Re: Re: Re: Re: Re: Re: Re: Spare Tire Question - Will stock spare clear 13" brakes?
And that somehow keeps your tires from ever going flat? Interesting..........I think I will take my chances with conventional tires and AAA for now LOL
Old Jun 22, 2004 | 04:05 PM
  #486
Steve in Seattle's Avatar
Not to mention they're hard as rocks and loud as a KISS concert. Ask any C5 owner, they'll tell you what they think of run-flat tires.
Old Jun 22, 2004 | 04:34 PM
  #487
Originally posted by lateapex
The only spare that I know would fit correctly is the 17” C4 (4th gen Corvette) space saver spare. It was designed to fit over 13” front rotors. It came on 1989 and later C4’s. It was included on earlier C4’s which had the performance package which included 13” brakes and 17” wheels. It is a 155/70 17, which calculates to a 25.54” diameter.
The problem: I do not think that the 4th gen F-body spare tire well could accommodate the additional diameter of the C4 spare. If someone is interested, maybe they could go by a wrecking yard and test fit a 17” C4 spare in the well.
Forget that... I have a 17" C4 spare, as well as two 97-02 F-body spares...
The LS1 spare (actually my early-'97 came with this size spare so it's NOT just from 98+ cars) fits fine in the wheel well, kind of a tight squeeze, but you *can* make it fit. The C4 spare? good luck... even deflated it's a nightmare (although a valid option to fitment, I guess don't know if the carcass can handle being deflated for months/years like that before being reinflated).
The most interesting solution? Any convertible owner who has had the carpeting out of their trunk knows about the small tab that is tack-welded in the center of the front wall... and the tire-clearance indent in the rear wall. I tried using the U-hook from my stock spare to hold down the C4 spare in the dead center of the trunk and it worked good... until I hear one tack weld give way.
If you used a ful-sized spare, or even the C4 spare to save "some" trunk space, you'll want to grind and fully-weld the tab onto the trunk wall... the tack welds just won't hold. Maybe you could get the spare rim chromed and incorporate it into a stereo system layout or somthing.
Personally, I'm just going with AAA unless I'm making a REALLY long road trip to no-where... then I'll just go with a full-sized spare and call it good.
Old Jun 22, 2004 | 06:49 PM
  #488
SpeedSpecialty's Avatar
UPDATE
Updated again...(just backup list additions)
1) ZLT195
2) BBZ
3) backrdrunner (last confirmed: 4/9/04, but last posted to CZ28.com on 6/6/04)
4) JWBerk94Z
5) sleeperZ96BT
6) richclv
7) No_Secrets
8) Steve in Seattle
9) Hyperspeed 97z28 <-- out - replaced by FLALS1 (e-mail sent!)
10) HTWLSS (1st Set)
11) jasycZ28
12) 94TA25ann
13) Chad Allen
14) SSTAT
15) chasmanZ28 <-- out - replaced by Rechtien (only if needed)
16) The Highlander (1st Set)
17) JasonD (Was The Highlander (2nd Set) <-- out)
18) NSSINR8 U
19) a5150ward
20) jmzlt1
21) anasazi
22) HTWLSS (2nd Set)
23) KenB
24) TCredTA95
25) Carlos01SS
26) FlatIronsZ
27) Rottluver (WAS 350350 <-- out - replaced by jasycZ28 <-- 2nd set out)
28) mrz28 73/97
29) TP121
30) SS#2420
31) z28barnett
32) INSANEZ
33) PediDr2
UPDATED BACKUP LIST
34) Rechtien (second set, will commit if needed) <-- MOVED TO 15
35) jasycZ28 (second set, will commit if needed) <-- MOVED TO 27, then OUT
36) Rottluver <-- MOVED TO 27, then PAID
37) JasonD (if needed) <-- MOVED TO 17, then PAID
38) FLALS1 <-- MOVED TO 9
39) goodboyx666
40) jgeorger
41) carnutz
42) Brian's 01 SS
43) SSlider
44) Brent94Z (via e-mail)
NOTICE:
Once again, I got a payment from someone who used an e-mail address that is not the same as what is used for this message board. Whoever also uses the e-mail address schottcs@edited.com, PLEASE e-mail me back or post here what your user name is! I have sent TWO e-mails asking for your message board user name and have not gotten ANY replies. We need to be able to verify this OR YOUR ORDER WILL BE CANCELLED!
ALSO
When Thursday comes and goes, those from the backup list that will be put in place of those who have not paid will get a few days extension to get their payment in. If you are on the backup list, BE READY!
ONE LAST THING...
We really hate to be a party pooper, but can those of you who are posting about technical issues that are not directly related to this GP please take the discussion from this thread to the brakes forum here? We'd like people involved in the GP to be able to easily read what is going on with it. Thanks!
Old Jun 22, 2004 | 06:52 PM
  #489
Originally posted by SSlider
Speedspecialty, please add me to backup list. I respond to emails within 24 hours, or if quicker response necessary, plz call me at 562-397-8776. Thank you.
Added!
Originally posted by FLALS1
SpeedSpeciality, (or anyone that got the e-mail)
Please send me the e-mail again to my home e-mail. For some reason I did not get it at my work one.
Thanks,
FLALS1
(FLALS1@aol.com)
Sent!
Old Jun 23, 2004 | 11:50 AM
  #490
anasazi's Avatar
not to be pushy or anything, but is there an updated ETA on when these might ship after looking at how its gone so far, time wise?
Old Jun 23, 2004 | 01:58 PM
  #491
If everything goes right, I think it is safe to assume mid-late July when they start shipping.
Old Jun 23, 2004 | 02:56 PM
  #492
jgeorger's Avatar
Re: UPDATE
Originally posted by SpeedSpecialty
ALSO
How are you going to work in people from the backup list? Does order matter or will it be a free-for-all? Just curious if I have to stay up late on Wed night to get my order in.
Thanks.....
Old Jun 23, 2004 | 05:04 PM
  #493
Brian's 01 SS's Avatar
Re: Re: UPDATE
Thanks.....
Good point, because I will pay as soon as I have to. I would pay now if you let me.
Man, I hope I make it!!!!!
Brian Bittle
Old Jun 23, 2004 | 07:31 PM
  #494
INSANEZ's Avatar
I cannot swing the money, I thought I could but I would need until this friday when I get paid. So whoever is next on the list, have fun with them because I know I would.
Old Jun 23, 2004 | 09:24 PM
  #495
Re: Re: UPDATE
They will shuffle into the list in the same order they were in the backup list. As an opening is created, it will be filled in the order of the backup list.
It doesn't look to be a problem, we may have to open this up to anyone. There appears to be more openeings now than people on the backup list.
Not a problem, things will continue moving ahead.
Tomorrow afternoon, I will move the people from the backup list into the buyers list and send them notification on how to place the order.
