Quick Roots ?
Quick Roots ?
Anyone have a roots styled pulley puller for a roots supercharger pulley. Just to show you it is not a standard pulley puller you need read below and go to the site and see the pic.
The OEM pulley is pressed on with tremendous force, up to a .002" press fit, resulting in more than six tons of pressure required to remove it. Through use and development, Pulleys Boys designed the three-bolt puller tool to be the toughest puller tool available. With all steel components, the best hardware available and the three-bolt design keeping the components aligned, this puller tool makes a pulley swap a routine procedure.
The Pulley Boys three-bolt puller tool includes:
(1) top plate (5/8" steel)
(1) back plate (1/2" steel)
(1) 5/8 main rod (B7 alloy)
(1) 5/8 high hex nut (Grade 8)
(2) 5/8 washers (Hardened)
(3) 3/8 bolts (Grade 5)
(3) 3/8 washers
(2) M8 studs (class 45H)
(2) M8 washer
http://www.pfyc.com/store/merchant.m...y_Code=GPUNDER
Pic Of puller
(3) 3/8 washers
(2) M8 washer
Pic Of puller
WobblySausage
Oct 7, 2015 02:44 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
