South Atlantic Delaware, Florida, Georgia, Maryland, North Carolina, South Carolina, Virginia, and West Virginia
i need a good mechanic
Old Apr 2, 2006 | 04:47 PM
anasazi's Avatar
i need the seal on the front of the axle replaced as well as possibly the seal on the tailshaft of the transmission replaced.
any recommendations on where to get this done?
my axle is leaking pretty bad now and its definantly not comming from the cover, and its being slung all over the bottom of the car by the driveshaft.
Old Apr 2, 2006 | 07:03 PM
MustangEater82's Avatar
Re: i need a good mechanic
that sucks... I believe I have a new seal form GM, sell it to you for $10 next meet? I think it was $22 new. I'll brign it out on wed night if you want...
I have had it for awhile...
Old Apr 3, 2006 | 12:29 PM
Mr. T's Z's Avatar
You need your pinion seal replaced? The tailshaft seal always has some slight seeping. I can help you out with that if needed. This is on the Camaro right?
Old Apr 3, 2006 | 12:55 PM
anasazi's Avatar
yea, a 1999.
it was just seeping but now its leaking so bad that when i stopped after getting off the highway at a stoplight all you could smell was burning gear lube from where it has been slung onto the exhaust pipe. the entire bottom of the car seems to be covered -- good for rust prevention
i replaced the trans tailshaft seal 2 years ago but it never really fixed that leak, just slowed it. i figure since the driveshaft has to come out anyways then it'd be a good time to do that seal again as well.
i don't know much about doing the pinion seal other than it requires tools i don't have.
Old Apr 3, 2006 | 01:00 PM
BlkLT1Z28's Avatar
The one thing that sucks is that the rear will probly need to be taken completly apart. You could just pull the yoke off without anything else out but who knows if you will get the pinion nut tight enough or to tight upon reassembly. How much are you looking to spend. I just built the 12 bolt in my bosses chevelle.
Old Apr 3, 2006 | 01:42 PM
anasazi's Avatar
the whole thing shouldn't need to be taken apart for just the seal. the guys on LS1tech said to take the driveshaft off and check for play so i'll do that tonight.
i'm a college student so i'm trying not to spend as much cash as possible, such as possibly going to a dealer.
Old Apr 3, 2006 | 02:02 PM
BlkLT1Z28's Avatar
Well, if you are lucky......unlike me then just taking the driveshaft out and popping off the pinion nut and pulling the yoke off will expose the seal but when you put it all back together there need to be a certain amount of preload on that crush bearing inside. Its usually anywhere from 14-19 inch pounds. But that is with no diff in the car. If you want I can help you do that, but no garantee on that. If it were me, I would try it that way before taking everything apart.....
Hell, what are you talking about, you collage students have allll the money
Old Apr 3, 2006 | 04:31 PM
TransAmAbe's Avatar
Check out Keliente's write-up over on LS1tech. Just one problem with it: she says to do the same thing that the tech who did mine did regarding replacing that pinion nut. Just doing it by feel will usually come out OK, but you could end up like me and have a rear end that howls like a bastard. All the time. It's louder than my LT's/ORY/Rumbler. But I've seen the same guy who did mine do about 3 or 4 pinion seals on Blazer's the exact same way (tighten pinion nut until it "feels right") with no differential noise whatsoever. Don't mean to scare you, just trying to give you some info.
Abe
Old Apr 3, 2006 | 05:47 PM
SFB767's Avatar
I had the same seepage your car is experiencing and my differential didn't have to be taken apart.
Give Harrell & Beverly Transmissions in Sanford a call. I think their number is 407-321/2-8410. They're about 15 min. north of UCF via 417. These guys are good.
Old Apr 4, 2006 | 08:37 AM
Mr. T's Z's Avatar
Give me a call I can hook you up. As far as tearing the differental down there is no need. I have replaced plenty of pinion seals. I am a GM Master certified and ASE master certified tech. That may mean nothing to you guys but I have experience to back it up ask anyone that knows me.
Old Apr 4, 2006 | 05:35 PM
SFB767's Avatar
Oh no, those are some great credentials to have.
My mech. has the same certifications and this guy is the **** with any car.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
Fatdog2
Feb 13, 2015 08:19 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
