South Atlantic Delaware, Florida, Georgia, Maryland, North Carolina, South Carolina, Virginia, and West Virginia
crane cams new project
Old May 24, 2003 | 07:13 PM
  #16
mrr23's Avatar
first of all...having a hood makes plenty difference. on the ls1 cars the air enters under the lid. so with the hood closed it doesn't get as much air as if open.
second....they have a fan it's about 4 feet in diameter.
also they run the engine at operating temp. they showed the car temp at the 195 range. most other places run the engines cold or maybe at 160. big difference there in numbers.
does this math make it better for you
266 divided by .83 (17% loss) = 320 so to me it's a more accurate way of dynoing. so when dynoing with hoods open, engines cold, air lids open, you get false higher readings.
Old May 24, 2003 | 07:37 PM
  #17
got_hp?'s Avatar
an n/a engine can only suck in a specific amount of air......i doubt that amount changes with the hood open or closed.
it would be interesting to do a back-to-back dyno testing to see if there is a difference.........im guessing less than 5.
as for having a fan, someone else said they did not.......i was just commenting on that.
Old May 24, 2003 | 07:52 PM
  #18
mrr23's Avatar
yes an engine can only suck i nx amount of air. but if the underneath of the hood is too close to the inlet, it will restrict the amount of air going in. just like any air intake design. for the lt1 cars for instance. taking the stock ducting off and putting the k/n FIPK kit has shown up to 20 peak hp more. has nothing to do wit hhow much the engine can pull in. has more to do with intake tract restrictions not allowing the amount of air needed to get in. yes one day someone should do a back to back run. vinci said they have on the SS cars and it picked up. seeing as how the air enters the center of the hood makes a 180* turn to get to the front. then makes another 180* turn to get into the air lid.
as for the fan, just clearing up that they do have one. so no misinformation is out there.
pic of the inground dynojet with big blue fan:
http://www.camaroworld.com/nitrometh...5_04%20007.jpg
and yes we are cheating that day with the hoods up. but the hoods on thirdgens don't cause any restriction. and no that's not me. here's mine. the governer broke i nmy tranny during the first run. so only had 1st gear. no n2o run yet. maybe in 2 weeks.
http://www.camaroworld.com/nitrometh...5_04%20010.jpg
Old May 24, 2003 | 10:21 PM
  #19
JimMueller's Avatar
The only person who made a reference to a fan was me. I wrote:
Please remember that Vinci has a policy of dyno'ing all cars with the hood down. I'm not sure if they use fans. This does make a large difference in the results.
Don't put words in my mouth. I've already seen the back-to-back dynos firsthand, but I can't find anything on the web for proof. I'd suggest you do a back-to-back test on an LS1 since you want to disprove the statement.
Old May 24, 2003 | 10:41 PM
  #20
JimMueller's Avatar
Here's one from a 1996 Ram-Air TA, best I can find so far:
Dyno hood open vs. closed
Old May 24, 2003 | 11:45 PM
  #21
mrr23's Avatar
and to think the pontiac ram air doesn't have all the turns a SS hood has.
Old May 24, 2003 | 11:50 PM
  #22
got_hp?'s Avatar
i was thinking of CAI cars...........i can see how it makes a difference on ramair cars!
Old May 24, 2003 | 11:54 PM
  #23
mrr23's Avatar
even still imagine the restriction a non ram air hood has if the ram air makes power over stock. but yes cold air kits for non ram air hoods make no difference.
oldschool
Feb 9, 2016 09:21 PM
nikolt1
Feb 27, 2015 09:10 PM
Don 97 SS
Jul 11, 2005 08:50 AM
donot_4get
Sep 14, 2002 08:03 AM
