South Atlantic Delaware, Florida, Georgia, Maryland, North Carolina, South Carolina, Virginia, and West Virginia
attn DanBUCF....
Old Jun 9, 2005 | 07:37 PM
teke184's Avatar
attn DanBUCF....
you have one of the fastest basic bolt-on LS1s i know of...
did you ever get it to the track after the LT header install??
bored and curious...
Old Jun 9, 2005 | 07:57 PM
DanBUCF's Avatar
Re: attn DanBUCF....
I brought it to the track twice after the LT's...but couldn't get traction to save my life. Though I did pick up 2-3 mph. It'll trap 113 pretty consistently now w/out traction. Hopefully one of these days, I'll get some traction and give it a good flogging down the 1/4...though it probably won't be at Orlando Speed World. It went 12.7xx on street tires spinning pretty bad. The 12.57 run was on drag radials.
Old Jun 10, 2005 | 08:02 AM
teke184's Avatar
you think it's got 12.2s in it??
i'm still dying to get my z to a track. i've never ran it, even before the cam...
but i'm sure i'll have similar problems...not to mention i'm a noobe at the track..only went 2 times with my old 96z
Old Jun 10, 2005 | 09:05 AM
DanBUCF's Avatar
I'm pretty confident its got a 12.2, possibly a 12.1 in it with sticky tires, good track prep, and decent air...it'll have to be one of those nights when all the planets align for that to happen.
Old Jun 10, 2005 | 09:32 AM
blackz151's Avatar
come to moroso ull get tracktion hah
Old Jun 11, 2005 | 03:58 PM
LT1Brutus's Avatar
Yo dan, mike just got those steam-roller ZR1 wheels and the Nitto 315s are supposedly on the way. I'm sure you could get enough traction to snap a driveline part w/ those
Old Jun 12, 2005 | 08:18 AM
86 IROC's Avatar
12.2 is definately possible, I did a 12.292 on a weak 1.896 60 ft. I trapped 112.54 that pass. Since It's gotten hotter I've only been pulling mid to high 111 traps, 110 if I hot lap it. I'm working on making it leave harder, hoping to improve from my current best of a 1.746 60' to a 1.68 or better this fall. More hook + cold air will hopefully = 12.00's or faster for me.
Dan, if you're feeling brave I have some P255/50-16 M/T DR's you can borrow sometime. I won't be racing my car for another 4-5 months. I hate racing the car in the heat.
Old Jun 13, 2005 | 08:06 AM
DanBUCF's Avatar
Your converter definitely helps ya out leaving the line...I wish I could pull those kind of 60's. My best to date is a 1.86 on 245 nitto drag radials. Those Mickey Thompson drag radials are F'ing BAD! I may have to take you up on that offer...I definitely need to look into getting a set for myself. I think a set of those + cool air + any track in the state other than OSW and I should be running 12.1... But who knows really? Won't find out until I actually do it.
Old Jun 13, 2005 | 12:10 PM
86 IROC's Avatar
Dan, the converter makes it a whole new car... the shift extension alone is worth the price of admission. But, it's a soft hit converter - only a measly 1.63 STR. I could be 60'ing a bit better w/ a harder hiting converter and more tire, but it wouldn't drive as nice as it does now. I have tons of crap in the works to make the car leave better. I spent a good 20-30 minutes at the BMR booth durring the HOT ROD Power Tour last Friday. I need to get 1.6's or better to run any kind of ET.
My tires bite good at OSW, when they put some glue down. Drew & Scott saw first hand how bad they spin when the track isn't prepped. I did a 2.06 60 ft. & ended up w/ a 12.833 @ 111.30 MPH. That same night I was able to go 12.26 & two 12.24's back to back with some track prep.
Anyhow, if you want to use the tires one night to see for yourself if they might work for ya - the offer is good for whenever.
Old Jun 13, 2005 | 01:04 PM
DanBUCF's Avatar
Thanks Brian...I appreciate the offer. I'll probably take you up on that offer whenever I get a chance to make it out there...right now, I am up to my ears in work and don't see this changing anytime in the near future. Hell, I drove the camaro on friday for the first time in about 3 weeks.
Old Jun 13, 2005 | 04:02 PM
86 IROC's Avatar
NP Dan, I won't be using them for about 4 months. And even then, I won't be racing the car 2-3 times a week every week.
jaykar
Wheels and Tires
Mar 15, 2007 09:22 AM
Maldo
Oct 4, 2005 11:24 AM
Maldo
Oct 3, 2005 04:07 PM
