South Atlantic Delaware, Florida, Georgia, Maryland, North Carolina, South Carolina, Virginia, and West Virginia
10 bolt explosion!!!!
Old 02-20-2011, 09:28 AM
mightymouse383's Avatar
Well went out to Orlando SpeedWorld last night to run the sportsman class and on my first run of the day at launch my 10 bolt just exploded!!!!! Had to tow the car and now its time to get a 9 in. or a s60.
Took it apart this morning and both of the main caps in the housing cracked in half and the ring gear was in about 10 peices!!!
The car hooked like a motha and all I heard was a loud *** boom!!!!.....lol
mightymouse383 is offline
Old 02-20-2011, 10:22 AM
Wild Willy's Avatar
Re: 10 bolt explosion!!!!
Lots of power will break things, and the cheapest thing to break is traction. Start hooking, and other parts will fail- in the F-bodies, the weak rear axle- GM used the correct axle for the vehicle weight but not the amount of power. Twisted driveshafts, snapped universals,- I fragged a planetary gearset in an LT1 powered Caprice with a shift kit, Eaton, and 4.10 gears once. Something's gotta give-
Wild Willy is offline
Old 02-21-2011, 08:54 PM
1957camaro's Avatar
Yep...
The 7 5/8 rears are not the "strong ones".
Built back in the late 70's as 7.5's to handle the smog 150 hp engines...
Strange builds a bolt in 60 series Dana, that is NO "BS" strong!!!
But if you want to change gears, you will need a "housing spreader" to get the center carrier out...
So the 9 inch is the "Bong"... EZ out and in... Build it in the bench...
We will see how my 8.5 holds up on the '57 (Strange spool & 3.90 gear)
1957camaro is offline
F'n1996Z28SS
08-23-2023 11:19 PM
Victor Lamb
08-26-2017 02:52 PM
maybe2fast
03-16-2015 09:45 AM
Quick Reply: 10 bolt explosion!!!!
