Fans do not turn on... and headlights are on when not supposed to.
Well.. I got this strange problem.. The fans are not turning on and the car heated up a bit.... They are not even turning on when reflashing my PCM
The headlights are turned on always ... very very dim, but they shouldn't be on...and if you turn them on.. only one of them will light up correctly.. the rest are still dim...
What is the problem here???????????????????????????????????
A bad ground? relay? are the headlights and fans connected in some way?? I will check my manual tonight, but I have no clue...
How can I test the fans???
Magenta_Hearts
Mar 25, 2015 10:24 AM
mspennyhughes
Mar 1, 2015 03:50 PM
ChrisFrez
Feb 15, 2015 08:12 AM
formula79
26
Aug 5, 2002 12:21 PM
