Driving cant pass a limit
Old Aug 26, 2018 | 12:36 PM
Thedog's Avatar
Got camaro z28 1994 once the car is on 55 to 60 mph and at 2000 rpm the car starts to like shake and does a pop wont let me pass that .could it be the catalytic converter but got that changed 2 months ago
Old Aug 26, 2018 | 05:14 PM
HardcoreRM125's Avatar
Re: Driving cant pass a limit
No codes? Have you scanned it?
Are you sure it is MPH and not drivetime? Does it do it cold as well as hot? What does it do under wide open throttle?
Does the Check Engine light flash? That would be indicative of a misfire.
Any modifications done to the car?
Old Aug 26, 2018 | 05:23 PM
Thedog's Avatar
Nope no codes no light and no modifications and its starts to sputter and like sluggish
Old Aug 26, 2018 | 09:32 PM
No misfire detection in OBD-1. That was added in 1996 with OBD-2.
Does sound like misfires, due to an ignition problem, resulting from the stress of lugging the engine at low RPM. Check all ignition components - coil, wires, plugs. Maybe the Opti cap.
Old Aug 27, 2018 | 06:08 PM
If it is all original, as old as it is I would certainly check (or just R&R) the spark plugs and wires. Test the coil.
If all checks out well and the problem still persists; test the Optispark, following ShoeBox's instructions to the T.
Zrout
Jan 1, 2011 12:48 AM
steven92f
May 13, 2009 11:56 AM
brando1985
Jun 12, 2005 12:27 AM
lt1powerd
Apr 12, 2004 02:54 PM
