Egr vacuum feed line
I have been trying to find the egr vacuum feed line for the egr selnoid that connects to the drivers side of the intake on an lt1. The part has been discontinued, so does anyone have any suggestions on what to use as a replace or no where I can find a used one. None of the junk yards around here even have an lt1 much less the vacuum feed. TYIA
Re: Egr vacuum feed line
Decent sized auto parts stores usually have a huge selection of vacuum fittings and lines you can use to make up a line that is pretty close to stock. Rubber elbows and some plastic line the correct size should work.
96 TA
Feb 8, 2013 10:19 AM
flaminfoster
Apr 10, 2008 05:22 PM
ZDriver96
Aug 27, 2004 02:10 PM
HardcoreRM125
Jul 30, 2003 10:27 PM
