On the fuel rails, which connector is for the feed line and which is the return line
Old Jul 29, 2003 | 03:29 PM
HardcoreRM125's Avatar
Where the fuel lines connect to the fuel rails, there is two connectors. One is vertical and the other is horizontal, which one is for the input line and which is for the fuel return line ?
Old Jul 29, 2003 | 03:59 PM
Vertical and horizontal? Mine are kinda side by side. 3/8" feed line (front) and 5/16" return line (off the end of the regulator).
Old Jul 29, 2003 | 04:04 PM
Thats strange that mine is different ... One of the connectors is about a inch and a half further towards the back , and it is vertical. The closer ( To the front ) connector is horizontal
Old Jul 30, 2003 | 07:42 AM
sdodd's Avatar
On the fuel rail, the bigger (3/8") line is for the feed and the smaller (5/16") line is for the return.
take care,
simon
Old Jul 30, 2003 | 12:32 PM
Back of Intake.
The larger diameter line is the fuel supply line, and goes into the back of the passenger side rail. It has the Schrader valve on it. The slightly smaller diameter line is the fuel return, and it attaches to the fuel pressure regulator, which in turn mounts on the end of the drivers side rail.
Exaclty which lines are you talking about, with regard to vertical and horizontal?
Old Jul 30, 2003 | 10:27 PM
The actual post that the fuel line connects too. One of the posts is horizontal, while the other is vertical.
HectorM52
Jul 30, 2017 11:46 AM
birdblack
Dec 30, 2014 06:59 PM
Jul 4, 2005 05:00 PM
Wilson
Jul 21, 2002 05:08 PM
