lighting issues on a 1997 camaro .... HELP
Old Jan 24, 2012 | 12:16 PM
jproz1167's Avatar
I hit a deep pothole sometime back I am not sure if this is a coincendence or not but at that time the front left turn signal has never worked again. Nor the DRL on the left/front since then.
here are some basics that are known
No electrical tampering has ever been done to this car, I have owned it since brand new.
lights off .. depress brake pedal all brake lights work
lights on ... depress brake pedal L/R tail-light shuts off
lights off ... Ignition on R/F drl lights up L/F does not
lights on ... car running ... R/F drl on only parking light comes for turn signal bulb
car running ... hazard lights flash normally ... R turn signal front and rear flash ... Left rear turn signal will illuminate but not flash
DRL automatically turns lights on and off normally
dimmer switch seems fine
no fuse issues
new bulbs through out car have been replaced and problem persists.
I figure since mine has issues surely others have as well.
I also should add from I believe the DRL heat from bulb has browned my front turn signal sockets and Im wondering if perhaps they have internally shorted and causing the problem with the L/R brake light.
Old Jan 24, 2012 | 03:24 PM
Re: lighting issues on a 1997 camaro .... HELP
Not exactly an "Advanced Tech" topic.... let's try moving this to "General 67-02 F-Body Tech".
sdn1997rs
Dec 30, 2014 08:30 AM
bernie1951
Dec 10, 2014 10:03 AM
siguy
Nov 27, 2014 10:07 AM
ChrisFrez
Nov 23, 2014 10:33 AM
