Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Search for help on a 2000 Z28 camaro fuel pump replacement
Old Oct 18, 2011 | 06:26 PM
jraquel's Avatar
I am sorry, but I can not seem to find any help with a search (may be looking in wrong way or place) on how to get to the fuel pump on my 2000 z28. Is it in the "top" of the tank? Not much room when I lift the back window hatch up and carpet is fastened down fairly good and do not want to explore around until I am fairly sure what I am doing. I did see a video of someone who had to cut an access hole bigger to get to his but it was an earlier model than 2000. Looks like pulling the tank is a real major project.
Can someone please help me out.
Thanks and Have a Great Day,
JRAQUEL
Old Oct 18, 2011 | 07:54 PM
Kevin Blown 95 TA's Avatar
Re: Search for help on a 2000 Z28 camaro fuel pump replacement
yes, it is in the top of the tank. Two methods - by the book, you remove the exhaust and drop the tank or else you have to cut an access panel and go that route.
Old Oct 18, 2011 | 09:33 PM
jraquel's Avatar
Thanks Kevin.
So there is no access hole there at all? Not even a small one? Just have to cut one? Is the pump basically in the center of the "hump"?
Thanks and Have a Great day,
jraquel
Old Oct 18, 2011 | 10:37 PM
There is no access port of any kind - just solid sheet metal. On the "topic" listing page of this forum, at the top are "stickies".... the answers to frequently asked questions. One of them tells how to access the pump on a 99. Yours will be identical:
https://www.camaroz28.com/forums/sho...d.php?t=810959
Old Oct 19, 2011 | 06:50 AM
jraquel's Avatar
Thanks Fred.
Have a Great Day,
jraquel
Old Oct 20, 2011 | 09:38 PM
jraquel's Avatar
Another question.
Does this 2000 camero have a "reset" switch for the fuel pump? Seems like I remember where some cars do or did have a reset switch.
jraquel
Old Oct 21, 2011 | 12:47 PM
Originally Posted by jraquel
Another question.
Does this 2000 camaro have a "reset" switch for the fuel pump? Seems like I remember where some cars do or did have a reset switch.
jraquel
None I know of.
Hurin
Dec 13, 2014 07:38 PM
pologreen97z
Dec 2, 2014 10:42 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Mad_Ice
Jul 29, 2002 09:44 PM
2000silverz28
Jul 20, 2002 06:14 AM
