Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
OPTI Sustainment
Old Oct 1, 2011 | 04:14 AM
dacappel's Avatar
OPTI Sustainment
I have 1996 Z28 with 383 Stroker and MSD Ingnition. My problem is that I eat OPTI SPARK Distributors. When I used the Delco is took about 200 to 350 mile to burn the contact in the distributor to point were they did not conduct/pass electricity. I went to MSD OPTI and I managed about 1000 mile before the OPTI spark failed. Why do is there so much current flowing through distributor and what can I do to fix or surconvent this problem?
Old Oct 1, 2011 | 06:33 AM
Re: OPTI Sustainment
Are the contacts actually burning, or are they being damaged by the rotor being pushed into them by a cam dowel pin that's too long?
Do you have any kind of aftermarket ignition box, like an MSD?
What gap do you run on your spark plugs? What is the engine's dynamic compression ratio?
Old Oct 3, 2011 | 09:30 PM
punkslapper's Avatar
I went thru a few optis with similar time frames as yours . I removed my msd ignition and have not bought another opti in almost 5000 miles and counting
Old Oct 4, 2011 | 10:31 PM
He hasn't been back to the site since he posted this.
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
