Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel pressure test
Old Oct 4, 2011 | 11:50 PM
Rij1's Avatar
Fuel pressure test
I did a fuel pressure test on my car. When i turn the key to the on position with the car off the pressure gauge jumps to 42-43 psi then drops to 35 rite after. When I drive the car the pressure is at 35 untill I give it more gas to wot then it goes to 42-42 till I let off. Is this normal
Old Oct 5, 2011 | 12:16 AM
JGuy07's Avatar
Re: Fuel pressure test
It drops to 35 when you start the engine, or does it hit 42psi when you turn the key on and then drop off before starting the engine? The specs say for fuel pressure when engine is off power on to be anywhere from 41-47 psi or so. Then when you start the engine it is suppose to drop anywhere from 3-9 psi and it's normal.
Old Oct 5, 2011 | 12:40 AM
Rij1's Avatar
When I turn the key and the fuel pump turns on and I get 42 psi. As the key is on still the pressure drops to35 within a 2 seconds without me turning the engine on. It just drops it doesn't slowly go down. When I crank it the engine idles with 35 psi till I Rev it wot.
Old Oct 5, 2011 | 01:21 AM
JGuy07's Avatar
Yea it should not drop down to 35 while you're sitting there. And what you explained in your first post was that you did take the car for a good run while watching your pressure gauge?
Some fuel could just be bleeding back down the lines to the tank. Have you checked the fuel pump yet, do you have the "fuel pump hatch" mod?
Old Oct 5, 2011 | 07:47 AM
I would not be concerned at this point. Your pressures when driving sound normal.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
greenzee28
Mar 26, 2015 09:13 AM
Gtpguy
Jan 26, 2015 04:50 PM
Jul 4, 2005 05:00 PM
