How easy is to replace the rear control arm bushings?
Old Jun 13, 2011 | 01:23 PM
jethrobodean's Avatar
Do you need a press to remove and replace the rear trailing arm bushings? If so, $30 for each side bushings and $30 to have them pressed out and in...I might as buy new arms....Any suggestions? Daily driver 6 speed....
Old Jun 13, 2011 | 03:19 PM
Guest47904's Avatar
Guest
Re: How easy is to replace the rear control arm bushings?
No you don't need a press.
Here's one of the better choices
http://www.summitracing.com/parts/LAK-20140/
While you're at it might as well change your instant center to get better performance with these:
http://www.hawksthirdgenparts.com/ca...nbrackets.aspx
Old Jun 13, 2011 | 04:14 PM
my1994z28's Avatar
I agree with speedy,go with the Lakewood control arms,and relocation brackets.
Old Jun 14, 2011 | 05:22 AM
Wrong forum.... the is LT1 Based ENGINE Tech.
Moving to Suspension, Chassis and Brakes.
Jason Short
Jan 19, 2015 06:34 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
slothgrant
Aug 22, 2002 03:01 PM
