97 Z28 eating strut mounts
Old May 17, 2011 | 08:54 AM
55sedan's Avatar
I bought a 97 Z28 2 years ago. The car is stock except for air intake & exhaust. It is very clean & well kept. It had 110,000 on it at purchase time. When I bought the car the previous owner had just replaced the struts & mounts about a month before. I have only put 10,000 miles on the car in 2 years. (10,000 friendly miles on good smooth roads) I have put 2 sets of struts & mounts in those 10,000 miles & it just broke another set. Its busting the middle out of the strut mounts. The 1st set were Autozone, the 2nd were KBY & the 3rd TRW. I can not find any logical reason for this to be happening. Does anybody out there have any answers? Thanks
Old May 17, 2011 | 09:06 AM
95TA04GOAT's Avatar
Re: 97 Z28 eating strut mounts
My only thought is maybe they're being installed wrong. Possibly a missing washer. I could imagine that the first set was maybe installed incorrectly and then the subsequent sets were installed to match the first.
Old May 20, 2011 | 08:26 PM
TraceZ's Avatar
do you have them swapped right for left? If so the geometry will be off and could very easily result in them breaking.
Old May 20, 2011 | 11:05 PM
There are upper and lower rubber reinforcement pieces that the upper shock (its not a "strut") shaft passes through, and sandwich the mount in between, and strengthen it. Are both those in place.
Shoebox has an assembly diagram:
http://shbox.com/1/front_suspension.jpg
Old May 20, 2011 | 11:56 PM
55sedan's Avatar
Injuneer, The reinforcement pieces you are talking about are not there. Just the "shock" shaft passing through the mount. This must be the problem. I guess they were left out when the previous owner had them changed. Are these pieces available at an auto parts, dealer, or aftermarket ? Thanks everyone for your help & input.
Old May 21, 2011 | 07:53 AM
I would assume they were available somewhere. When I did my shocks it was about 12 years ago, and the factory parts were fairly cheap from the online discount parts dealers.
1996LT1Z28
Jan 14, 2015 08:09 AM
Alien
West South Central
Jan 11, 2015 12:51 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
Absolute Z28
Jul 19, 2002 02:21 PM
