Brake problems
Old Feb 20, 2011 | 03:08 PM
Big Shrimp's Avatar
Brake problems
Hi guys nooby here with brake problems. I have a 97 Camero with a 3800 motor and auto trans. My prob starts with the abs light on. My mom inlaw had the car before me and her mech told her to not worry about it. No big prob the brakes still worked. Now I guess I let the resivour get low or I had a leak and it got air in the system. I tried to bleed the system and did fine at the modulater but I'm not getting any fluid at the rear brake bleeders and the pedal will not pump up and get stif like you get when you have air in the lines. The Haynes book says it may be a bad check valve but I can't find anything about a check valve in the repair section. Could any one help me out with this problem?
Old Feb 20, 2011 | 03:19 PM
Re: Brake problems
The ABS light doesn't come on for air in the system, low fluid, etc. That would cause the "BRAKE" light to come on for uneven pressure in the front and rear braking circuits. Once you have a code in the EBCM (ABS computer) you usually have to use a Tech-2 or similar to "home" the ABS motors before you can bleed them correctly.
ABS INOP usually is a problem with a wheel speed sensor or other ABS system component. Yes, with that light on the brakes still work, but they no longer have the anti-lock braking feature.
Old Feb 20, 2011 | 04:17 PM
Big Shrimp's Avatar
Re: Brake problems
Thank you for your response Injuneer. So what you are saying is I have to take the car to a shop to have my brakes bled.
Old Feb 20, 2011 | 11:06 PM
Re: Brake problems
Yes. And to find out what turned on the "ABS INOP" light.
Old Feb 21, 2011 | 06:43 PM
Big Shrimp's Avatar
Re: Brake problems
Thank you sir. I was hoping I wouldn't have to go to one of those vile places. I hate taking my car to somone I know is going to rip me off for somthing I should be able to do myself. Thanks for your help.
Magenta_Hearts
Mar 25, 2015 10:24 AM
dluna333
15
Mar 13, 2015 12:30 PM
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
