Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
problem with 96 camaro not starting after warmed up
Old Jan 25, 2011 | 08:53 PM
Glassguy06's Avatar
Unhappy problem with 96 camaro not starting after warmed up
This is what I have, A 96 camaro z28 5.8LT1. I can start the car, after it warms up , and i stop somewhere and turn it off, it wont start again.
It sounds like it isnt getting gas or spark. what can it be?
Old Jan 26, 2011 | 06:00 PM
manfire1987's Avatar
Re: problem with 96 camaro not starting after warmed up
possible fuel pump issue, maybe plugged fuel filter.. after it warms up is what is crazy... hhmm
Old Jan 26, 2011 | 11:50 PM
Glassguy06's Avatar
may be the coil????? or no
Old May 7, 2011 | 03:38 PM
Trog116's Avatar
I am having a similar problem with my 96. After I stop and try and restart the vehicle it will not start unless I hold the accelerator to the floor. Have you figured it out yet?
Old May 7, 2011 | 07:46 PM
Holding the accel pedal to the floor puts the PCM in "clear flood" mode. Could be a problem with leaking injector(s), or possibly a coolant temp sensor that isn't correctly telling the PCM the engine is warmed up and doesn't need the enriched cold start.
Red Hawk 94
Mar 18, 2019 04:03 PM
97SSdude
Dec 31, 2014 07:43 PM
jj71787
Dec 30, 2014 02:15 PM
Injuneer
Dec 15, 2014 09:36 AM
Snoman73
Nov 17, 2014 07:22 PM
