Antifreeze pouring out the exhaust/misfiring problem
Old Jun 20, 2010 | 12:16 PM
d2stephen's Avatar
Exclamation Antifreeze pouring out the exhaust/misfiring problem
Well, for a few weeks now I've been having problems with my car bogging and misfiring really bad. Pulled into a parking lot today and smoke was pouring out of my exhaust, to the point where it looked like my car was on fire. Started it up later in the day and it hesitated, then bogged like crazy, idling at around 400 RPM, and antifreeze was just dumping out of the exhaust, theres a nice size puddle on the ground infront of each exhaust opening.
So, is this my head gasket, intake manifold gasket, or some other thing that i'm not aware of?
Any help would be appreciated...
Old Jun 20, 2010 | 12:23 PM
z28beast's Avatar
dude that sounds like a head gasket to me
Old Jun 20, 2010 | 12:44 PM
rclearyiii's Avatar
Head gasket..Intake does not have water circulate through it on a LT1.
Old Jun 20, 2010 | 09:36 PM
Dtimekw's Avatar
If you are unsure that it's a head gasket, do a cooling system leak down test but since it's burning off in the combustion chamber (white smoke out of the exhaust) coolant is leaking into the cylinder and probably a head gasket. Not a big deal to change (do both sides), just take your time and do it right. Don't forget the apply thread sealant (like ARP thread sealant or teflon liquid thread sealant) to the head bolt threads. Be sure and follow the torque specs and sequence. Also, make sure you use new intake gaskets and RTV in the front and back of the block where the intake meets the block. If you have any questions along the way, post them here, plenty of experience on this forum.
Old Jun 21, 2010 | 08:30 AM
aboatguy's Avatar
As already stated LT1 intakes are dry so best case scenario you're replacing a head gasket....
Mike
Magenta_Hearts
Mar 29, 2017 08:54 PM
AlaskaZ28
Apr 17, 2015 08:54 AM
warmeck
Mar 1, 2015 08:47 PM
ProudPony
Aug 29, 2002 04:20 PM
Brady
Jul 29, 2002 10:30 PM
