20's or not
Old Dec 15, 2009 | 07:23 PM
baileyr1978's Avatar
20's or not
i got a 94 z28 with t's i am looking for a good wheel combo.. i like the 20in iroc rim but dont kmow how it would ride and or handle ie rubbing i also like some 18s and 19s i saw but every pic i sceen the car has been lowered and i dont want to lower the car so are 20s the best bet to fill the wheel well any advice would be greatly considered
Old Jan 27, 2010 | 07:22 PM
YodiBrodi's Avatar
best advice, leave the 20's for the donk, box, and bubble crowd. 18's look great on 4th gens and don't fill the wheel well so much that they exaggerate the fender gap at the top of the tire.
Old Jan 29, 2010 | 09:14 AM
If you choose the wheels with the correct offset, and put the right size tires on them, nothing will rub.
That said, 20's are strictly for "show"", not for go. The thin sidewall will severely limit straight line traction, and the combination of a solid rear axle, and the low compliance provided by the thin sidewall will severly hamper cornering capabilities. 20's work fine with an independant rear suspension (IRS) like the Corvette and the 5th Gen Camaro, because the suspension provides the compliance, not the tires.
Additionally, if you choose the tires correctly, matching as closely as possible the stock tire diameter, you won't close up the tire/fender gap very much. Put an excessivley large diameter tire on it, and it will close up the gap, but its going to look like an SUV, not a sports car.
Old Jan 29, 2010 | 02:07 PM
Mikes 1994 z28's Avatar
Please dont wreck a 4th gen fbody with 20s. Go 18" max
Old Jan 29, 2010 | 06:30 PM
94CamaroZ28/SSClone's Avatar
Yea 20s will just look bad on a Camaro. Max size would be 18s.
