Little weird problem can anyone help
ok i have a 95 trans am and when i start the car the low oil light comes on and it runs horrible for 2-3 mins, then starts running fine and if you turn the car on for thirty seconds to a minute then shut it off and start it back up the light goes off and it runs fine i havent looked into it at all it just started doing it about two days ago and i havent driven it since but i dont know what else it could be other than a sensor.
I have a Canton pan and the sensor is so close to the header that you can't plug the connector in so I put the sensor in, cut the plug and made a pig tail so I can connect and disconnect the low oil light. If I change the sensor, I will have to remove the header
After I cut the wire I wrapped everything in the foil reflective tape.
ya i actually pulled over right when it came on and checked the the oil on it, it was fine and i have checked it several times since, (i used to drive a 5.0 that used oil bad and have a habit of checking oil all the time... it is a good habit though). Where is the oil sensor at?
The Oil Level Sensor is located about 2" above the oil drain plug... more or less. It is on the same side of the pan.
My oil level sensor pigtail was factory loomed under the oil cooler lines to the radiator which keeps them tight to the engine.
Dylan Latshaw
Mar 21, 2015 09:48 AM
Magenta_Hearts
Mar 5, 2015 07:01 AM
