325 on summit star wheels
Old Apr 26, 2009 | 02:59 PM
95z28_m6's Avatar
Has anybody ever fit a set of 325's on a pair of summit star 15x10 rims with the goofy 6.5in backspacing? Is it even possible or will I rub the inside of the fender?
Old Apr 26, 2009 | 10:49 PM
Definitely won't rub on the inside of the fender. The 6.5" backspace will put the tire outside the fender. You need a 7.5" backspace. I have an ET Drag 28x10.5-15W, which is exactly the same section width (13.1") and within 1/10" on the diameter (28.0" vs. 28.1") as the M/T ET Street Radial 325/50-15, and it doesn't rub on the inside of the fender with the correct 7.5" backspace. But my wheels wells were already hammered for 315's on 17x11's.
The 28" diameter shouldn't be a problem, since the radials don't "grow" like a bias-ply slick, but with the tire outside the fender, if the body squats at all, the fender lip is going to come right down on the sidewall or the tread.
Old Apr 27, 2009 | 11:15 AM
95z28_m6's Avatar
I am running drag bags, drag shocks, and lca. The rear sits up pretty good, I wonder if I will have a problem with hitting the fender. My buddy ran these same rims, but I don't know if he ran a 28 in tire. Thanks Injuneer.
Old Apr 28, 2009 | 07:31 PM
This is the same width tire, same diameter tire, on the same width wheel, but with a 7.5" backspace. The outer edge of your tire will be 1" more toward being outside the fender with the 6.5" BS..
Old Apr 28, 2009 | 07:48 PM
95z28_m6's Avatar
Yea the look of being out another inch doesn't bug me any. I am just worried that the 28 in tall tire will rub the bottom lip of the fender. I cant really tell from that picture, but how much clearance between the fender and the top of the tire do you have?
Old Apr 28, 2009 | 07:58 PM
mdacton's Avatar
Its not going to work with the 6.50 bs.
unless you get some air shocks and jack up the back end like the 70's
Old Apr 29, 2009 | 05:28 AM
Click on the "Trailer Queen" link in my signature. I have Eibach Drag Launch springs in the back, so it sits maybe 1/2 taller than stock.
Old Apr 29, 2009 | 12:34 PM
95z28_m6's Avatar
I think that I will just have to wait and try to find a deal on some used pro stars with the correct backspacing. How do you like those drag launch springs? Did you notice any real difference over stock springs? Your car looks downright nasty. Me likey.
HarleyZ28
Oct 5, 2015 06:23 AM
BLK1997Z28
May 1, 2015 12:23 PM
Matt W
Apr 24, 2015 12:54 AM
ChrisFrez
Nov 23, 2014 10:33 AM
Elcojoe
Nov 17, 2014 10:27 PM
