swap 94 3.4 v6 camaro with a LT1
I have a 1994 camaro with a bad 3.4 v6. I just got an 93 Z28 camaro that was wrecked with good motor and trans. What all will i need off this car to fix my 94 camaro. Thanks to anybody that helps
The answer to your question is the reason I have a 3.4 Camaro and a Z-28 Camaro. By the time I looked at the work involved and the money involved in the swap, it was a better decision to just buy the Z. If you really want to do it, though, you'll need to use the K-member, complete wiring harness, and gauges from the Z-28, and I'm sure there's more that I don't know because I just haven't done it.
See my avatar, green car= 1995 3.4L, Green motor= LT1 thats currently in the green car
It really is a PITA, but you can do it. I'm accually taking the lt1 out of the green car now and putting it in a firebird... I'm on a firebird kick now...
.It really is a PITA, but you can do it. I'm accually taking the lt1 out of the green car now and putting it in a firebird... I'm on a firebird kick now...
thanks to everybody that has helped. I picked up a wrecked z28 for a $1000 and i've got the rear ends and motor switched over now im just to the odds and end so it should running soon hopefuly
Ls1 over lt1
Honestly if i had a pony car camaro and wanted to do an engine swap i would just go ahead and throw an ls1 in there. The lt1's are good and all but the ls1's have the latest in materials, electronics, and engine design philosophy.
Brandon Wittmer
Dec 7, 2014 12:15 PM
Jul 4, 2005 05:00 PM
