Milodon 180* High-Flow LT1
Old Oct 31, 2008 | 10:51 AM
ninetysixZ28's Avatar
Will I have problems if I use a Milodon 180* high-flow thermostat on my 96 Z28 LT1?
Milodon 16401
Old Oct 31, 2008 | 11:50 AM
moparman's Avatar
The pic looks like the stat for a SBC. It will not work properly. The LT1 takes a specific stat.
Old Oct 31, 2008 | 12:15 PM
mdacton's Avatar
You need a LT1 specific thermostat
http://store.summitracing.com/partde...4&autoview=sku
Old Oct 31, 2008 | 01:00 PM
seawolf06's Avatar
And it won't change anything if you don't have your fans reprogrammed.
Old Oct 31, 2008 | 05:28 PM
Thanks! Installed new LT1.
Old Oct 31, 2008 | 09:11 PM
Thanks!
Working on getting a programmer but would like to just borrow someone elses just to reprogram fans.
I know that current settings should be:
PRIMARY: ON @ 226* OFF @ 221*
SECONDARY: ON @ 235* OFF @ 230*
What would the 'reprogram' settings be for a new 180* in South Texas heat?
Old Oct 31, 2008 | 09:31 PM
Stl94LT1's Avatar
Originally Posted by ninetysixZ28
Thanks!
If you are talking about a hand held programmer, they will only work on one car at a time. They can't be shared.
Old Oct 31, 2008 | 09:43 PM
seawolf06's Avatar
That's correct.
I have mine set at 82.25 and 86 degrees Celsius.
Old Oct 31, 2008 | 10:17 PM
Wasn't thinking...will get programmer...
Thats:
Primary: 82.25 on ?? off
secondary: 86 on ?? off
your thoughts on the offs? I'm new to this so if this is proprietary racing info then my apologies and nvm...
Old Nov 1, 2008 | 07:11 AM
Since the stock t'stat in an LT1 is 180*F, and you replaced it with a new one of the same rating, changing the fan on/off temps is of questionable value. It would make more sense to reprogram the temps if you bought a 160. You definitely do not want to use the 82.25*C (180*F) and 86*C (186.8*F) temps with a 180* t'stat. It only starts to open at 180.... isn't fully open to ~200*F, so you would be reducing flow significantly with those low temps. If you feel you have to reprogram it, use temperatures above 200*F. Or get a 160.
Old Nov 1, 2008 | 11:03 AM
seawolf06's Avatar
Yeah, I'm using a 160* thermostat. With a programmer you won't have a choice of what temps, it just does it for you.
Programmers are generally understood on this site to be pretty worthless. You won't get any benefit from lowering the running temps on the car and the other gains are minimal. Spend your money on other mods and get a pcm tune when you feel the need.
Old Nov 1, 2008 | 02:09 PM
Actually, the HPP offers two different sets of fan on/off temps, and dyno tests have shown that the only real HP gain from the programmer is seen when the 160*F t'stat is used. Still not a good "bang for the buck", but it does work.
Old Nov 1, 2008 | 02:45 PM
Thanks!
Will leave as is for now and go with 160*/reprogram later.
Have plenty of other issues to deal with.
HectorM52
Jun 23, 2016 08:42 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
blue89iroc
Jul 26, 2002 04:56 PM
blue89iroc
Jul 18, 2002 04:41 PM
blue89iroc
Jul 18, 2002 03:35 PM
