Stock Wires + Pacesetter LT's = ?
I Just bought all new AC Delco plugs and wires for my Z but haven't installed them yet. I'm planning on getting Pacesetter LT's and just thought that I won't be able to use those wires I just spent 90 bucks on am I?
Yes you can, you just have to route them from underneath using zip ties. I'm currently running a bolt on motor and used the motor mounts to zip tie too as well as each other to keep them from touching.
get a couple of "firesleeves" , those heat resistant fabric plug wire sleeves and run all or a couple of wires through one on each side where they are closest to the primarys.
And yes, plenty of zip ties. double check them.
