stock lt1 flexplate?
Old Oct 7, 2008 | 07:34 AM
firstlast's Avatar
is it neutrally balanced?
Old Oct 7, 2008 | 07:57 AM
cnorton's Avatar
No.
Old Oct 7, 2008 | 08:04 AM
firstlast's Avatar
ive got one in my 355 which is internally balanced above 4000 rpms the motor vibrates a bit i think that is what it is
Old Oct 7, 2008 | 08:16 AM
cnorton's Avatar
If your rotating assembly is internally balanced and you have a counter-weighted flexplate, it's not surprising that you have a vibration. At least, it's a relatively easy fix.
Old Oct 7, 2008 | 08:22 AM
firstlast's Avatar
should i get a new one or can mine be de-weighted?
Old Oct 7, 2008 | 08:41 AM
cnorton's Avatar
My personal preference would be to simply buy an unweighted flexplate. I've never removed a counterweight to see if the plate balances after surgery although it might. Don't forget that the one-piece rear main seal crankshaft bolt pattern is not the same as a early small block.
Good luck.
c
Old Oct 7, 2008 | 01:18 PM
firstlast's Avatar
ill check with my clutch shop and see of they can de-weight it and make it neutrally balanced
Old Oct 7, 2008 | 02:05 PM
Stroked96Bowtie's Avatar
Or you can paypal me 50$ and I will send you a zero wieghted TCI flexplate
Old Oct 7, 2008 | 04:38 PM
firstlast's Avatar
mine is a manual. sorry for the miswording. i should have said flywheel
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
