Plug wire routing?
Old Sep 26, 2008 | 01:03 AM
henryz28's Avatar
Plug wire routing?
My car has ran like crap for a whial now. I was able to pull two plug wires off and it would idle the same. So after rulling out the coil and icm I went out and got a new GM opti, new plugs and I replaced my worn out autozone wires with MSD supper conductors. Only paid $60 for the wires after I got credit for the cheap autozone wires. My question is on the passanger side the wires will not work in the stock routing. I noticed there is a gap between the pully bracket and the block; directly to the left of the opti under the WP. I know the number 2 plug wire will not work but I think I will be able to run the other three wires through there and up to the plugs. what do you guys think? I also have heat sleves for the wires.
Old Sep 26, 2008 | 01:08 AM
Green96Z's Avatar
They will fit through the stock routing behind the power steering pump. You have to rip out the old plastic track, then use zip ties to keep the wires from moving. The #2 wire has to be very carefully positioned or you can destroy it on the tensioner pulley.
Old Sep 26, 2008 | 01:59 AM
henryz28's Avatar
Ok thanks if it does not work out the way I plan atleast I know I can just remove the track and run the wires in the stock position.
Old Sep 26, 2008 | 02:12 AM
jhthornley's Avatar
I removed the track and used zip ties too.. better than stock IMO
Old Sep 27, 2008 | 12:05 AM
henryz28's Avatar
I ended up running the number 2 plug wire in the stock position but I ran the others through the space between the block ond pully mounting bracket. It turned out great.
Old Sep 27, 2008 | 03:55 PM
LaredoZ28's Avatar
I've run mine in the stok routing and it works great. I wana try going over the valve cover though.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
grgguy
17
Feb 23, 2015 07:57 PM
