1996 lt1 Harmonic Balancer help
Old Sep 11, 2008 | 10:27 PM
quickchek321's Avatar
hi guy i just bought a Harmonic Balancer from jegs and the keyway on the crankshaft and the keyway on the balancer hub fits right but the hub is not at tdc it a 1:30 on a clock; is this ok
Old Sep 11, 2008 | 10:28 PM
texastransam96's Avatar
the balancer is a nuetral balance so i dont think it matters which way it is bolted on as long as it is bolted on... i know stock ones you just bolt on and torque down to the proper specifications... if thats a standard replacement it should be the same way i would imagine
help help
Old Sep 11, 2008 | 10:31 PM
well i guess you right but why would jegs do that isn't it better if it was tdc
just to clarify this is an lt1 you are talking about correct? i just saw that this was posted in the v6 forums, so it may be a reason you havent gotten a lot of hits on the answer ....
edit.. i believe the keyway is cut in some of them to give them a little more added stability in not spinning on the crankshaft .. but there arent any timing marks to go by on the crankshaft to be able to tell if it is at TDC or not with the way the ignition is set up and the fact that it is a neutral balance
Old Sep 11, 2008 | 10:34 PM
Green96Z's Avatar
To clarify again, do you have a stock crank with the stock key? Because the stock hub is an interference fit, not a keyway fit.
Thumbs up
no it is a lt1 i just register in this website i really don't know it to well sorry
Old Sep 11, 2008 | 10:36 PM
well i mess up the old hub so a replace it with a new one and a new Harmonic balacner
Old Sep 11, 2008 | 10:37 PM
isnt the jegs brand balancer only able to be used if you use there hub that they sell because of the way it bolts up ? i assumed he had the jegs hub from talking about the keyways and the fact it is aftermarket
Old Sep 11, 2008 | 10:39 PM
is it ok that Harmonic Balancer a 1:30 everything is a tdc
Old Sep 11, 2008 | 10:40 PM
yea you can only use there hub for there balancer
Old Sep 11, 2008 | 10:42 PM
yeah it should be ok, you shouldnt have any problems whatsoever
Old Sep 11, 2008 | 10:45 PM
are you postive because i put about 5 grand in this engine i don' want the crank to break on me from vibration
Old Sep 11, 2008 | 10:47 PM
it is a nuetral balance.. you wont have it break.. you can put it on whatever way you feel like to be honest with you, as long as the engine is balance properly and for a nuetral balance harmonic balancer you will not have any problems with it.. i have put that balancer on a friends car before and it went on just fine and he hasnt had any problems to date ...
Old Sep 11, 2008 | 10:50 PM
thank u for ur help
oldschool
Feb 9, 2016 09:21 PM
cyteone
Feb 7, 2015 06:04 PM
siguy
Nov 27, 2014 10:07 AM
smokin5s
Jul 24, 2003 10:47 PM
1LEThumper
Jul 14, 2003 12:45 PM
