yet another cam question
Old Jul 26, 2008 | 09:34 AM
CamaroRSguy's Avatar
Well my 355 is getting closer to being complete. I'm going for a higher reving 355 for road racing, aiming for 6500-6800 max RPMs. right now i have a comp 224/230 112 lsa cam in the motor from the last setup. Should I consider a new cam? I've read alot about the comp 306, is that a better option?
Old Jul 26, 2008 | 02:50 PM
Mtxz453's Avatar
check out ai's 226/234, it'll definetly wake that 355 up a little more and be where it sounds like you want to be
Old Jul 26, 2008 | 03:35 PM
'94 Bad A Z28's Avatar
I would just call Comp or whoever and tell them your plans for the car and they will suggest a cam for you.
Old Jul 26, 2008 | 04:32 PM
thanks for the help!
Old Jul 26, 2008 | 05:34 PM
NightTrain66's Avatar
A cam in the mid to high 220 duration range might allow you to 'rev" to 6800 RPM but it will be done making power before then, I would suggest something in the low 230 duration range and maybe a mid to high 230 duration range depending on where you want the power band to start at.
Lloyd
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
