the correct tool
Old Jun 9, 2008 | 07:45 PM
camaroLevi's Avatar
Exclamation the correct tool
what exactly is the correct tool and way to take off the crankshaft pulley.. i tried with a wrench and it jus kept turning counter-clockwise...anyhelp would def. help thanks in advance><
Old Jun 9, 2008 | 08:27 PM
RealDealZ28's Avatar
You need the correct crankshaft/pulley puller to take it off. Are you familiar with a steering wheel puller? If so, the crankshaft one is similar; using an impact gun, take the bolt out of the center of the crankshaft pulley, then thread the puller in and use it to press the pulley out of place.
Old Jun 9, 2008 | 09:24 PM
camaroLevi's Avatar
ok ok so i was told by several people' "oh this shoold be easy job to do" well why does what u just explained sound NOT easy,,, i CAN borrow my friends impact drill .,but what else will i need to get for the job,..are these tools cheap or inexpensive to buy???mind u this is a 3.8 v6 not an ls1
Old Jun 9, 2008 | 11:41 PM
Garcia95's Avatar
go to autozone they rent specialty tools there u might just find what u need
Old Jun 10, 2008 | 07:15 AM
Dude, calm down. It's not nearly as hard as it sounds. Remove the original bolt in the pulley, thread in the puller, and pull the pulley off. Even with no experience, you can do it in 5 minutes tops.
Like someone else said, go to Autozone or another local parts store; lots of times, they will have these tools available for rental. Once you have the puller in your hand, it's going to be obvious how it works.
Old Jun 10, 2008 | 08:57 AM
94-TAGT's Avatar
Why in the world do you have three threads on this subject.. you could have asked this in the same thread where I told you to go get the tool?
The "friendly" people at autozone will tell you which tool you need. Its on a chart on the parts counter. Flip it over if you don't read spanish =P.
Old Jun 10, 2008 | 06:18 PM
camaroLevi's Avatar
Smile
thanks again 4 the info., sorry bout the threads ill delete the other
Old Jun 22, 2008 | 03:52 PM
camaroLevi's Avatar
Angry oh
im guessin that was a racist slure...anyhow im italian,born in jacksonville, florida,....so i went to autozone and they told me it was a 23% interest charge meaning i had to rent it out for 23% of the original price of the tool or buy , i feel like they are trying to do me,..and i mean like "do me" as jip me on money...help anyone???
Old Jun 22, 2008 | 07:28 PM
BC2002SS's Avatar
in CT you have to pay full price when you get it, than you get it back when you bring it back in.
Old Jun 23, 2008 | 10:53 AM
94-TAGT's Avatar
I wasn't being racist... its always in spanish when I go in to the store.
Ours is like the last guy posted you buy it and then return it within so many days and thats how they "loan it".
If they are trying to charge you interest thats crap - try a different parts store like O'reillys.
Old Jun 23, 2008 | 03:32 PM
camaroLevi's Avatar
[ thanks for the info guys , I'll be going as soon as i get my paycheck.
Old Jun 24, 2008 | 08:45 PM
smithtim's Avatar
defintley worth waiting!
I got fustrated once and tried to pull one of those whells off ( think power steering) with an engine bearing puller I had sitting around.... Well I ended up paying nearlly $100 to replace the think as I bent the hell out of it.
Good think is that even with the deposit when all is said and done you spend $0 to use the tool.
Old Jun 24, 2008 | 09:21 PM
mdacton's Avatar
its very simple.....buy a repair manual, it will explain it.
You will need an installer to press it back on too, don't knock it on with a hammer or try to pull it on with the bolt.
take a chill pill too.
When you rent the autozone tools here you have to pay for the tool...100% then get a refund when you return it, so the autozone "friends" may want to do you.....but not jip you
Aaront810
Aug 29, 2020 09:34 PM
marlar98
Sep 12, 2018 07:18 AM
drt
Sep 27, 2015 04:39 PM
Fatdog2
Sep 16, 2015 11:04 PM
tommalcolm
Sep 11, 2015 03:39 PM
