problems running compression test
Old Jun 7, 2008 | 01:51 PM
Jeremy1's Avatar
Question problems running compression test
Trying to run a compression test on my 3.4l. Started the engine to warm it up. Shut it down, pulled the driver side plugs (side i was concerned about) and pulled the PCM ING fuse and the IGNITION fuse that is under the hood (per instructions in my trusty Haynes manual). Put the gauge in, but nothing happens when I turn the key. Engine does not crank. What am I doing wrong?
Old Jun 9, 2008 | 01:51 PM
94-TAGT's Avatar
instead of pulling the fuse... maybe just just unhook the power from the back of the ignition coils?
on my brothers car we just unhooked the injector so that it wouldn't dump fuel and left the spark alone.
Old Jun 10, 2008 | 09:01 AM
Jeremy1's Avatar
thanks for the advice. got it working
Old Jun 24, 2008 | 08:39 PM
smithtim's Avatar
either or.. personally I've always gone plug in the ICM... wierd what haynes says probably kills a whole circuit???
F'n1996Z28SS
Aug 23, 2023 11:19 PM
slothgrant
Aug 22, 2002 03:01 PM
naaz90
Jul 27, 2002 08:22 AM
