what size injectors should i run.
right now i have the mods in my sig with the addition of a comp. cc305cam. i know its a mild cam but soon i plan on stepping up to a le2 or similar heads/cam package.
i would like to know, if i buy bigger injectors now, is there a size that will work good with both combos when tuned. i was thinking of getting 28 or 30lb injectors but would that be too much for what i have right now? if anyones got an info id appreciate it, i really do not wanna buy 2 sets of injectors.
Injectors are sized based on flywheel HP, not rear wheel. At 430rwHP on an M6, you are going to be around 500 flywheel HP. With an "average" tune (0.475 BSFC) a set of 30 #/HR injectors will be at just about 100% duty cycle. Not a good idea to stress your injectors by running them at 100% DC. A 35 #/HR injector would be a better choice (85% DC). There is no problem with running a larger injector, as long as you have the PCM programmed with the correct flow rate and offsets.
