what size injectors should i run.
Old Dec 9, 2007 | 02:45 PM
sn8ke eatr's Avatar
right now i have the mods in my sig with the addition of a comp. cc305cam. i know its a mild cam but soon i plan on stepping up to a le2 or similar heads/cam package.
i would like to know, if i buy bigger injectors now, is there a size that will work good with both combos when tuned. i was thinking of getting 28 or 30lb injectors but would that be too much for what i have right now? if anyones got an info id appreciate it, i really do not wanna buy 2 sets of injectors.
Old Dec 9, 2007 | 03:30 PM
Stl94LT1's Avatar
For now, you should be OK with the stock injectors. When you upgrade to the LE2 the 30's will work well, or the 30's would work with either combination.
Old Dec 9, 2007 | 03:39 PM
96m6lt1's Avatar
the stock injectors will suffice..
Old Dec 9, 2007 | 05:44 PM
Z-RATED94's Avatar
30lb. injectors would work for now and later. Like you said, no need to buy them twice. My Ford 30lb. SVO's have worked well for me.
Old Dec 10, 2007 | 01:23 PM
sn8ke eatr's Avatar
alright thanks guys looks like ill order a set of 30's. thanks for the advice.
Old Dec 10, 2007 | 01:57 PM
What kind of flywheel HP are you envisioning for the future? A good heads/cam package may need more than the 30's.
Old Dec 11, 2007 | 10:34 AM
sn8ke eatr's Avatar
in the future i would estimate having somewhere in the neighborhood of 410-430rwhp, that shouldnt be too much for 30's should it?
Old Dec 11, 2007 | 05:21 PM
Injectors are sized based on flywheel HP, not rear wheel. At 430rwHP on an M6, you are going to be around 500 flywheel HP. With an "average" tune (0.475 BSFC) a set of 30 #/HR injectors will be at just about 100% duty cycle. Not a good idea to stress your injectors by running them at 100% DC. A 35 #/HR injector would be a better choice (85% DC). There is no problem with running a larger injector, as long as you have the PCM programmed with the correct flow rate and offsets.
Old Dec 11, 2007 | 05:41 PM
z275plus's Avatar
The stock ones would be fine for now.
Old Dec 11, 2007 | 06:23 PM
sn8ke eatr's Avatar
hmmm good advice, thanks guys. im probably gonna get the 30's for now and figure if i go above 450-475fwhp ill stop up to some 36's or so. thanks again
HectorM52
Jul 30, 2017 11:46 AM
QuickSilver02
Apr 7, 2015 11:12 AM
drptop70ss
Mar 26, 2015 01:50 AM
1775.Z28
Jan 11, 2015 10:51 AM
