Bad exhaust leak on EGR tube.
Old Nov 3, 2007 | 05:39 PM
mrmint69's Avatar
Found a bad exhaust leak today. Its coming out the top of the egr connect to the exhaust manifold. The connection is a bolt at the bottom and it should press fit but it leaks bad. I took some foil and wrapped it around the connection and it stopped for now. Is there a correct and permanent fix for this? The design is a bad one having only one bolt hold the fittings together.
Old Nov 3, 2007 | 11:19 PM
Moshbmx1's Avatar
block it off......
Old Nov 3, 2007 | 11:28 PM
windsma's Avatar
are there any plugs for the stock exhaust manifold to block off the egr.
Old Nov 4, 2007 | 08:21 AM
Moshbmx1's Avatar
I believe that these will work....
http://www.rdspeed.com/product.sc?ca...=4&productId=1
Old Nov 4, 2007 | 09:12 AM
Greed4Speed's Avatar
I just got some thin steel sheet metal and made my own block off plate. The mating surface on the EGR makes for a great template. After I removed the EGR, I did the same with some thicker aluminum.
You could also use some copper gasket sealer. Run a bead on the mating surface and bolt your egr down.
Old Nov 4, 2007 | 10:56 AM
Did you try removing the bolt that holds the tube to the exhaust manifold, cleaning off both sides of the connection, cleaning out the threads in the manifold, and cutting a piece of high temp gasket material to fit the flange that bolts to the exhaust manifold? Add some very high temp sensor-safe RTV to the gasket to insure a good seal. If all you want to do is block it off, get the correct blocking plate from sjmmanufacturing.com
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
Iamherefornow
Jan 26, 2015 04:57 PM
Jan 5, 2015 07:14 PM
