383 stroker questions
Take your NA (no nitrous) flywheel HP, and multiply it by 0.07 That will give you the smallest injector you should consider. Generally, the LT1 dry kits raise the fuel pressure when you spray, so you size injectors for NA HP. If you have some other kind of dry kit, you'll have to let us know how it works.
