Removed oil cooler - what closes the lines?
My old motor had an oil cooler on it but it was damaged when the motor was removed. If you were to have a car without an oil cooler, what happens to the connections on the water pump and radiator? I capped them off, but it constantly cracks the caps. If there is a hse in it's place with a restrictor or anything, please let me know.
It is number 16 in the pic. It goes from the water pump to the radiator. It says the part number is 10197675. http://shbox.com/1/93-94_hoses.jpg
I went down to NAPA at lunch and got the hose for it. Anybody else have trouble with the OEM oil cooler leaking from the Oil filter base? Mine was and in the the process of replacing it I set the motor down on the new one and then said screw it. Hopefully this will not affect the car to much.
If anything, it might help the motor out a little bit. When I did the Oil Cooler delete, I noticed higher oil pressure right away. From my understanding the oil cooler is only necessary if you are into Autocross or something similar. At that point, an aftermarket cooler should be used anyways.
squarehead
Nov 21, 2014 08:02 PM
