Removed oil cooler - what closes the lines?
Old Jun 21, 2007 | 11:06 AM
DirtyDan's Avatar
My old motor had an oil cooler on it but it was damaged when the motor was removed. If you were to have a car without an oil cooler, what happens to the connections on the water pump and radiator? I capped them off, but it constantly cracks the caps. If there is a hse in it's place with a restrictor or anything, please let me know.
Old Jun 21, 2007 | 11:10 AM
bingo's Avatar
It is number 16 in the pic. It goes from the water pump to the radiator. It says the part number is 10197675. http://shbox.com/1/93-94_hoses.jpg
Old Jun 21, 2007 | 11:21 AM
DirtyDan's Avatar
Cool, thanks for the quick reply.
Old Jun 21, 2007 | 11:22 AM
seawolf06's Avatar
I just cut the two hoses to the oil cooler and then connected them with a barb fitting and hose clamps. Works like a charm.
Old Jun 21, 2007 | 11:42 AM
wrd1972's Avatar
Simple rubber hose from the parts house for less than $10.00 or so. Make sure it fits the larder diameter water pump fitting and then cut the smaller end to the correct length. Piece of cake.
Old Jun 21, 2007 | 01:48 PM
DirtyDan's Avatar
I went down to NAPA at lunch and got the hose for it. Anybody else have trouble with the OEM oil cooler leaking from the Oil filter base? Mine was and in the the process of replacing it I set the motor down on the new one and then said screw it. Hopefully this will not affect the car to much.
Old Jun 21, 2007 | 03:07 PM
Sinister95Z's Avatar
If anything, it might help the motor out a little bit. When I did the Oil Cooler delete, I noticed higher oil pressure right away. From my understanding the oil cooler is only necessary if you are into Autocross or something similar. At that point, an aftermarket cooler should be used anyways.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
squarehead
Nov 21, 2014 08:02 PM
97 RedSS
Jun 10, 2003 07:58 PM
