What kind of metal are the cam bearings made of?
Old Apr 11, 2007 | 01:16 PM
BradcTA's Avatar
I have some aluminum metal shavings in my oil and I think I may have wiped out a bearing so I was needing too know if any of the bearings are aluminum.
Old Apr 11, 2007 | 02:09 PM
White96Z28's Avatar
They are actually several different kinds of metal that are put together. I can't remember what the process is called, but it's almost like they're laminated...
Old Apr 11, 2007 | 02:23 PM
BradcTA's Avatar
As long as aluminum is not the top coat I'm be happy. I think it's called tri-metal or something like that. Whatever kind of metal is in my oil filter it doesn't stick to a magnet. Summit bearings say tri-metal is copper-lead alloy.
Old Apr 11, 2007 | 02:49 PM
RUDEDOG's Avatar
Babbit metal. Lead or tin based alloy.
Old Apr 11, 2007 | 03:11 PM
BradcTA's Avatar
Awesome!! Thanks a lot! Now the ultimate question: Does babbit metal stick to a magnet???
rskrause's Avatar
Moderator
The bearing material varies with the manufacturer. But the only part that is magnetic is the backing, so just 'cause it's non-magnetic doesn't mean it's not bearing material.
http://www.roymech.co.uk/Useful_Tabl..._Bearings.html
Rich
Old Apr 11, 2007 | 03:34 PM
BradcTA's Avatar
OK, well it's just really small splinters of shiny metal in the filter. I'll take a pic later and post it.
LeftoverChinese
Jan 14, 2024 03:03 PM
Queens94z28
Dec 20, 2014 09:11 PM
Joes96z
Dec 13, 2014 07:48 PM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
