installing NSA rockers
Old Apr 11, 2007 | 03:13 PM
97ramairta's Avatar
is there a certain valve clearence needed for these rockers? any "how to's
" and tips would be awesome too.
Old Apr 11, 2007 | 03:26 PM
zx1216's Avatar
depends on what kind of lifters you have I say 1/4 turn of preload, seams to work good for me.
Old Apr 11, 2007 | 05:22 PM
97ramairta's Avatar
i think im going to just run stockers...i've heard too much bad **** about the comp R's. and you say 1/4 turn of preload....to get that do you just tighten the lock nut till its tight against the rocker then another 1/4 turn or what...never heard of that before. thanks
Old Apr 11, 2007 | 05:25 PM
turnin20s's Avatar
This should help http://shbox.com/1/4th_gen_tech2.html#adjust_valves
Also remember if you have aftermarket rocker arm studs, the thread count may be off. So a 1/4 turn on the stockers might only be a 1/8 turn on the aftermarket ones
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
alliance12364
Mar 6, 2015 04:39 PM
