valve dimensions
valve dimensions
I feel like this is a stupid questions - BUT
is the reference size of the valve the diameter of the bottom of the valve? And if I were to hold the stock valve and an oversized valve butt to butt would I see the difference?
Thanks.
Thanks.
Explain oversized valve.
The numbers that most people post about aftermarket valves are the bowl diameter, I guess that's what it's called. (2.0, 2.01, 1.6)
The stem diameter stays the same. 11/32" IIRC.
Opps - wrong forum...lol - gave you powerstroke valve sizing
Yes - you will visibly see the difference in an oversize valve. The stock valve size is 1.94"/1.50" with 11/32" stem
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
